Need for Speed Payback’s PC system requirements have been revealed
Need for Speed Payback's PC system requirements have been revealed
EA has released Need for Speed Payback’s PC system requirements, offering not only minimum hardware specifications but also framerate and settings targets for those machines.
These requirements confirm that Need for Speed Payback is a DirectX 11 title, with the game requiring a 64-bit OS and a minimum of four CPU threads to function.
When it comes to RAM EA recommends that users have at least 8GB of RAM for 1080p 60FPS gameplay and at least 4GB of VRAM, though systems with 6GB of RAM and 2GB of VRAM will be usable with lower graphical settings.
Below is a gameplay video from Nvidia which showcases 4K 60FPS gameplay from a system that uses a GTX 1080 Ti.
Launch is creeping ever closer and with that in mind we thought it was as good a time as any to talk PC specs. Whether you’re looking to run Need for Speed Payback on your reliable machine of a few years, or looking to push it to the limit with your brand new rig, you’ll find all the requirements below.
Minimum Requirements for 720p30 at low settings
OS: 64-bit Windows 7 or later
CPU: Intel i3 6300 @ 3.8GHz or AMD FX 8150 @ 3.6GHz with 4 hardware threads
RAM: 6GB
DISC DRIVE: DVD ROM drive required for installation only
HARD DRIVE: 30GB
VIDEO: NVIDIA GeForce® GTX 750 Ti or AMD Radeon™ HD 7850 or equivalent DX11 compatible GPU with 2GB of memory
DirectX: 11 Compatible video card or equivalent
INPUT: Dual analog controller
ONLINE CONNECTION REQUIREMENTS: 192 KBPS or faster Internet connection
Recommended Requirements for 1080p60 at high settings
OS: 64-bit Windows 10 or later
CPU: Intel i5 4690K @ 3.5GHz or AMD FX 8350 @ 4.0GHz with 4 hardware threads
RAM: 8GB
HARD DRIVE: 30GB
VIDEO: AMD Radeon™ RX 480 4GB, NVIDIA GeForce® GTX 1060 4GB or equivalent DX11 compatible GPU with 4GB of memory
ONLINE CONNECTION REQUIREMENTS: 512 KBPS or faster Internet connection
Need for Speed Payback will release on November 10th on PC, PS4 and Xbox One, releasing three days early for Deluxe Edition owners. The game will also receive a Play First Trial on November 2nd for EA Origin Access Subscribers.
You can join the discussion on Need for Speed Payback’s PC system requirements on the OC3D Forums.
