Nvidia release their own Mass Effect Andromeda PC system requirements
Nvidia has released their own Mass Effect Andromeda PC system requirements, stating that PC gamers will need a minimum of a GTX 660 for 720P gameplay and recommend a GTX 1060 or 970 for 1080p gameplay.
Mass Effect Andromeda will also come with HDR support on PC, with compatibility with Nvidia’s G-Sync HDR displays, which are set to release later this year.
Below is a collection of images which detail Mass Effect Andromeda’s graphical options menu.
Nvidia release their own Mass Effect Andromeda PC system requirements  Nvidia release their own Mass Effect Andromeda PC system requirements
(Mass Effect Andromeda PC Graphical options)
Nvidia has also released their own PC system requirements for the title, which lists the resolution that Nvidia expects PC users to play at.
For playing Mass Effect: Andromeda on PC, here’s what BioWare and Electronic Arts recommend for Minimum settings at 1280×720, and High settings at 1920×1080:
Mass Effect: Andromeda Minimum System Requirements For 1280×720
  • CPU: Intel Core i5-3570 or AMD FX 6350
  • GPU: GeForce GTX 660
  • RAM: 8GB
  • OS: Windows 7, Windows 8.1 or Windows 10 (64-bit versions)
  • HDD: 55GB free space
  • DirectX: Version 11
Mass Effect: Andromeda Recommended System Requirements For 1920×1080
  • CPU: Intel Core i7-4790 or AMD FX 8350
  • GPU: GeForce GTX 1060 3GB, or GeForce GTX 970
  • RAM: 16GB
Mass Effect Andromeda will be released on PC, PS4 and Xbox One on March 21st in the US and March 23rd in the EU.
You can join the discussion on Nvidia’s Mass Effect Andromeda PC system requirements on the OC3D Forums.
