Pro Evolution Soccer 2018 PC System requirements
Konami has officially released the PC system requirements of Pro Evolution Soccer 2018, which is set to release on PC on September 12th.
This game will release on PC, PS4, PS3, Xbox One and Xbox 360, with the game featuring support for up to three players on a single console for 3v3 online co-op matches.
The game will require a minimum of a quad core CPU, 8GB of system memory and a GPU with 2GB of VRAM and support for DirectX11. The game will also require 30GB of storage space. The game will release with support for Ultra-wide resolutions and 4K.
Minimum
OS: Windows 7 64-bit
CPU: Intel Core i5-3450 3.1 GHz or AMD FX-4100 3.6GHz
RAM: 8 GB System Memory
GPU RAM: 2GB Video Memory
GPU: GeForce GTX 650 or Radeon HD 7750 2GB
HDD: 30GB Available Hard Drive Space
DX: DirectX 11
Recommended
OS: Windows 10 64-bit
CPU: Intel Core i7-3770 3.4 GHz or AMD FX-4170 4.2 GHz
GPU: Nvidia GeForce GTX 660 or AMD Radeon HD 7950
DX: DirectX 11
You can join the discussion on PES 2018’s PC system requirements on the OC3D Forums.
