Ubisoft release For Honor’s PC system requirements
Ubisoft release For Honor's PC system requirements
Ubisoft has released For Honor’s PC system requirements, including hardware recommendations for 1080p 60FPS gameplay at high settings.
The game will require a GPU with at least 2GB of VRAM, though thankfully the game supports GPUs that range all the way back to the AMD HD 6000 series.  The game will support the DirectX 11 API and operating systems from Windows 7 or newer, though only 64-bit OS’ will be supported.
Below are the full PC system requirements for For Honor, requiring an Intel i3 550 CPU or an AMD Phenom II 955 or greater and a GPU with a minimum of 2GB of VRAM.
MINIMUM
Resolution: 720p @30FPS
Video Preset: Low
VSync: Off
OS: Windows 7, Windows 8.1, Windows 10 (64-bit versions only)
PROCESSOR: Intel Core i3-550 | AMD Phenom II X4 955 or equivalent
VIDEO CARD:
NVIDIA GeForce :GTX660/GTX750ti/GTX950/GTX1050 with 2 GB VRAM or more
AMD Radeon: HD6970/HD7870/R9 270/R9 370/RX460 with 2 GB VRAM or more
SYSTEM RAM: 4GB
RECOMMENDED
Resolution: 1080p@ ~60FPS
Video Preset: High
VSync: Off
PROCESSOR: Intel Core i5-2500K | AMD FX-6350 or equivalent
VIDEO CARD:
NVIDIA GeForce GTX680/GTX760/GTX970/GTX1060 with 2 GB VRAM or more
AMD Radeon R9 280X/R9 380/RX470 with 2 GB VRAM or more
SYSTEM RAM: 8GB
The game will support a wide range of controllers on PC, including the Xbox One gamepad and the PS4 Dualshock 4 controller. Additional controllers are supported, though some of these gamepads will require dedicated drivers.
Gamepad Support
• Mouse and Keyboard
• Microsoft Xbox 360
• Microsoft Xbox One
• Microsoft Xbox One Elite
• PlayStation 4 (Original/Pro)
Partially Supported Gamepads (May Require Third-Party Drivers)
• Any third-party Xbox-compatible controller
• Logitech Chillstream
• OUYA controller
• Steam controller
• PlayStation 3 controller
For Honor will be released on PC, PlayStation 4, and Xbox One on February 14.
You can join the discussion on For Honor’s PC system requirements on the OC3D Forums.
MINIMUM
Video Preset: Low
VSync: Off
VIDEO CARD:
SYSTEM RAM: 4GB
RECOMMENDED
Video Preset: High
VSync: Off
VIDEO CARD:
SYSTEM RAM: 8GB
Gamepad Support
• OUYA controller
• Steam controller
