Ubisoft releases Assassin’s Creed: Odyssey’s PC system requirements
Ubisoft releases Assassin's Creed: Odyssey's PC system requirements
Ubisoft has officially released the PC system requirements for Assassin’s Creed odyssey, which is set to release on PC in less than a month. This time, Ubisoft has partnered with AMD to develop Odyssey, a change which no doubt be music to the ears of Radeon and Ryzen users, thanks to AMD’s focus on both CPU and GPU performance when helping developers optimise their incoming releases.
Like Assassin’s Creed Origins, Odyssey will feature an integrated benchmarking mode as well as a range of graphical options that are not available to console users, offering a level of customisability that is now commonplace amongst AAA Ubisoft releases.
All of Odyssey’s PC system requirements are designed with 30FPS gameplay in mind, which means that PC gamers will require more powerful hardware if they want to push 60FPS framerates or higher. Like the console versions, the PC release of Assassin’s Creed odyssey offers players a dynamic resolution option, which can adjust the game’s resolution to maintain a high framerate.
     We are very pleased to share with you today some more information on the PC specs for Assassin’s Creed Odyssey. As was already the case for Assassin’s Creed Origins, the PC version is not a port of the console versions of the game, but a tailored experience developed by a dedicated team at Ubisoft Kiev in close collaboration with Ubisoft Québec, the lead studio on Odyssey.
Having a dedicated team on the PC version allows us to offer the level of customization that PC players expect, which will enable them to adapt the experience to their PC configuration. The PC version of Assassin’s Creed Odyssey will also include unique features not found in the console versions, such as benchmark tools to test the different graphics settings, and a toggle option for dynamic resolution rendering to uncap the framerate.
Below are Assassin’s Creed Odyssey’s PC system requirements, which are designed for 720p 30FPS at Low settings, 1080p 30FPS at High Settings and 4K 30FPS at High settings. The game is set to take up 46GB of HDD space when installed.
Minimum Requirements
OS: Windows 7 SP1, Windows 8.1, Windows 10 (64-bit versions only)
Processor: AMD FX 6300 @ 3.8 GHz, Intel Core i5 2400 @ 3.1 GHz, Ryzen 3 – 1200
Video: AMD Radeon R9 285 (2GB VRAM with Shader Model 5.0) or NVIDIA GeForce GTX 660
Memory: 8GB RAM
Resolution: 720p
Targeted framerate: 30 FPS
Video Preset: Low
Storage: 46GB available hard drive space
DirectX: DirectX June 2010 Redistributable
Sound: DirectX 9.0c compatible sound card with latest drivers
Recommended Specification
Processor: AMD FX-8350 @ 4.0 GHz, Intel Core i7-3770 @ 3.5 GHz, Ryzen 5 – 1400
Video: AMD Radeon R9 290X (4GB VRAM or more with Shader Model 5.0) or better or NVIDIA GeForce GTX 970 (4GB) – See supported list*
Memory: 8GB RAM
Resolution: 1080p
Video Preset: High
Recommended 4K Configuration
OS: Windows 10 (64-bit versions only)
Processor: AMD Ryzen 1700X @ 3.8 GHz, Intel Core i7 7700 @ 4.2 GHz
Video: AMD Vega 64, NVIDIA GeForce GTX 1080 (8GB VRAM with Shader Model 5.0)
Memory: 16GB RAM
Resolution: 4K
Video Preset: High
Assassin’s Creed Odyssey will release on PC, Xbox One and PS4 on October 5th.
You can join the discussion on Ubisoft’s Assassin’s Creed Origins PC system requirements on the OC3D Forums.
