Corsair HS70 Wireless Gaming Headset
Software
The HS70 is supported by the CUE software, allowing you to tweak the EQ to your own personal taste if you have a particular set of desires. Thankfully as this software isn’t available on the PS4 the HS70 default profile is outstanding. Usually even the best headsets require a little bit of fiddling either because they have a profile which is too flat and lifeless or – because the marketing department think that ridiculous bass is a positive quality – to smooth out an EQ too skewed in one direction. The HS70 has no such issues.
