The Budget Case King! NZXT S5 RGB PC Case Review
Meet the NZXT S5 RGB
The Best Value PC Case? Meet the NZXT S5 RGB
Many of NZXT’s newest products are focused on delivering pure PC value. First, we had the Kraken Core 360, an all-in-one CPU cooler that delivered excellent performance for its cost. Now, we are looking at the NZXT S5, a PC case that has an asking price of less than £50. That’s right! An NZXT PC case for less than £50.
It’s a challenging time for the PC market. RAM is extremely expensive, so most PC builders need to cut costs elsewhere. That means focusing on value elsewhere, and reusing parts wherever you can. With the S5, NZXT delivers a great-looking PC case without asking for too much in return. We expected some compromises to hit sub-£50 pricing, and honestly, this case has left us shocked.
What we have here is a PC case with two tempered glass side panels, a 360mm (3x120mm) single-frame reverse-blade fan set, space for up to a 360mm liquid cooling solution, and a front I/O that includes 1x USB 3.2 Gen 2×2 Type-C connector and two Type-C USB 3.2 Gen 1 ports. Not bad for £49.90.
NZXT S5 RGB vs S5 RGB Deluxe
NZXT’s S5 RGB is available in two forms. The S5 RGB comes with a single 3x120mm fan set, while the S5 RGB Deluxe ships with two additional fans. These extra fans are a rear NZXT RGB fan and a bottom-mounted NZXT RGB reverse-blade fan. Both models are available in black and white.
Pricing
NZXT’s S5 RGB series cases are budget-friendly, with the standard RGB model costing £49.90 and the RGB Deluxe model costing £59.90. This means that the Deluxe model’s extra two fans cost £5 each. This makes the Deluxe model better value if you intend to fill these fan slots.
