The Budget Case King! NZXT S5 RGB PC Case Review
Conclusion and Video
Extreme value! What more is there to say?
When I first heard about NZXT’s S5 RGB, I thought it was too good to be true. Where is the compromise? What’s the catch? Does the fine print ask for the soul of my firstborn? No, this case just does what it sets out to do: deliver a strong PC case option for budget-conscious PC builders. Honestly, with how expensive everything has gotten recently, it’s nice to see that £50 can now get you a solid PC case.
Don’t get me wrong. There are things to criticise about the NZXT S5. The thing is, all these problems can be countered with this: “It’s a £50 case; what did you expect?” The only thing that I think is worth mentioning is that I’d like a little more space behind the motherboard tray. Even so, that isn’t a big problem. For a sub-£50 case, it delivers surprisingly strong airflow. Clearly NZXT didn’t cheap out on its fans. It also didn’t cheap out with its PCIe slot covers. NZXT was tactical with its cost-cutting, resulting in a PC case that looks much more valuable than it is. Nicely done, NZXT.
On pricing, while I get the “under £50 PC case” angle of the S5 RGB, I must say the £59.90 NZXT S5 RGB Deluxe offers PC builders a stronger value proposition. Two extra fans for £5 each is a good deal. Those fans are matching fans too, and you’ll pay much more to get similar fans standalone.
NZXT understands what good value is
NZXT’s S5 proves you don’t need an expensive PC case for good airflow and a strong aesthetic. The black version of this case is almost perfect for NZXT’s budget-oriented Kraken Core 360 liquid cooler, which makes us lament that Kraken Core 360 isn’t available in white.
The NZXT S5 RGB is a PC case that truly deserves OC3D’s Valve for Money Award. That isn’t because it’s a £50 case; it’s because it is a great case that costs £50. NZXT understands that value doesn’t mean cheap. Value means getting a lot for what you spend. With component pricing being what it is right now, PC builders need to find value where they can. With the S5, NZXT is providing that value.
Join the discussion on our NZXT S5 PC case review on the OC3D Forums.
