NZXT Kraken 360 PLUS CPU Liquid Cooler Review
Meet the NZXT Kraken 360 PLUS
The NZXT Kraken Plus 360 RGB – A flashy but affordable CPU liquid cooler
Earlier this month we reviewed NZXT’s Kraken Core 360, and today we are looking at its more premium counterpart, the Kraken Plus 360. So what has changed? The Kraken Plus 360 has a 1.8-inch LCD, a single-frame RGB fan set, and an upgraded pump, Asetek’s Gen 9 pump.
Unlike the Kraken Core 360, the Plus 360 RGB is also available in both Black and White. That’s great news for fans of white PC builds.
Another change with the Kraken Plus 360 is its much nicer packaging. This isn’t a brown cardboard box with only black ink; this is fancier. This is kinda necessary when there are so many more features to talk about in the box. It’s also hard to showcase RGB lighting and an LCD screen’s features without colour.
A simple design
Much like the Kraken Core 360, the Kraken Plus 360 has a simple design. This unit has four cables. The single-frame fan has two cables, one for fan power and one for lighting. The pump unit also has two cables: a PWM connector to power the pump and a USB cable that can control the unit’s LCD. This unit comes with thermal paste pre-applied, making installation simple.
This CPU cooler supports all current AMD and Intel CPU sockets. This includes AMD AM4/AM5 and Intel LGA 1700, LGA 1851, and LGA 1954. Yes, this supports LGA 1954. That’s Intel’s next-generation CPU socket.
The single-frame RGB fan unit included with this cooler has an NZXT logo and clear sides. These clear sides make the RGB LEDs in this cooler stand out more.
NZXT CAM
NZXT CAM is used to control the Kraken Plus 360 RGB. It can control this cooler’s RGB lighting and LCD screen. This software also lets you adjust the orientation of images displayed on the cooler’s LCD, so they appear correctly regardless of how the cooler is oriented.
The screen
The LCD on the Kraken Plus 360 is 1.8 inches in size and has a resolution of 360×360. The screen has a brightness of 350 cd/m² and viewing angles of up to 160 degrees. This screen also operates at 60Hz, making it ideal for content playback.
RGB lighting
The clear, windowed sides of NZXT’s single-frame fan set let this cooler’s RGB lighting have a much bigger impact than standard RGB fans. The NZXT logo is also a nice touch.
Pricing
In the UK, the NZXT Kraken Plus 360 RGB is available for £134.90. This places this cooler on the more budget end of the “My CPU liquid cooling solution has an LCD” spectrum. This makes this cooler much more expensive than the Kraken Core 360 (See our review here), which is available for £71.90. That said, this CPU cooler lacks RGB fans and an LCD screen, and isn’t available in white. Fancy aesthetic features have a cost, but at least the Kraken Plus 360 RGB delivers these features without costing as much as some other brands.
Pump Speed is Limited without CAM
One oddity we noted with the Kraken Plus 360 was that its maximum pump speeds weren’t accessible when we used the CPU cooler without NZXT’s CAM software. Without CAM, this unit’s pump will not run above 1500 RPM. With CAM, it operated at up to 3400 RPM.
Since this cooler’s key feature, its LCD screen, requires CAM to be customised, this isn’t a major issue. That said, CAM is only available on Windows, so this could be a problem for Linux users.
OC3D CPU Cooler Test Rig Specifications
Recently, we built a new PC for CPU cooler testing. This new PC has a newer, hotter-running CPU, a more power-hungry graphics card, and a cooling layout that is common for today’s gaming PCs. Simply put, we have moved to more modern hardware so that we can better test modern CPU cooling solutions.
CPU: Intel i5-14600K @1.27V (Fixed)
Motherboard: ASUS ROG Strix Z790-E Gaming WIFI
Case: Custom Lian Li O11 EVO XL
Memory: G.Skill Trident Z5 Neo DDR5-6000 32GB (2x16GB)
GPU: Sapphire RX 7900 GRE Nitro+
PSU: be quiet Dark Power 1,000W
Fans: 4x be quiet Silent Wings 4 fans
