NZXT Kraken 360 PLUS CPU Liquid Cooler Review
Thermal Testing – Cinebench R24
OC3D CPU Cooler Stress Test
We want to push CPU coolers to their limit, and that requires a workload that will place maximum load on our i5-14600K CPU. Why didn’t we choose an i7 or an i9? The simple answer is that we want to test various CPU Cooler options. If we put the hottest CPU we could in our system, only the best of the best CPU coolers would even pass our testing procedures. Since not everyone uses such a power-hungry CPU, we decided to tone the wattage and thermal loads down by using an i5-14600K. Even so, this CPU consumes a lot of power and generates a lot of heat under all-core workloads.
For testing, we have used Cinebench R24. This is an all-core workload that places heavy strain on all available CPU cores. This load pushes CPU thermals higher than any other and does so consistently. We use Cinebench R24 for 30 minutes to see how hot our CPU gets over that time. If CPU temperatures rise to 100 degrees Celsius or over, that CPU cooler has failed our testing. This is part of the reason why there are more coolers on our higher fan RPM cooler charts. Some coolers will pass our thermal testing at higher fan RPMs but fail at lower fan RPMs.
1,000 RPM Fan Test
One thing we noted with the NZXT Kraken Plus 360 is that its thermal performance declined significantly when we dropped its fan speeds to 700 RPM. CPU thermals increased by over 10 degrees, indicating that this cooler runs optimally with fan speeds of 1,000 RPM or higher. Lower fan speeds will significantly reduce cooling performance.
At 1,000 RPM, the Kraken Core 360 slightly outperformed the Kraken Plus 360. At these speeds, both coolers are on par, with the Plus model offering improved aesthetics thanks to its LCD screen and RGB fans. Cooling-wise, both perform near-identically in this demanding thermal test.
1,500 RPM fan test
With fan speeds cranked up to 1,500 RPM, the Kraken Plus 360 RGB moves ahead of the Kraken Core 360, delivering a 1.6-degree drop in CPU thermals. While this is a relatively small difference, it does move the Kraken Plus 360 a lot further down our charts. A strong result for what is still a relatively low-cost CPU cooler.
Max RPM Fan Speed Test
At higher fan speeds, the gap between the Kraken Core 360 and Kraken Plus 360 RGB remains the same. Both coolers deliver solid performance, so the Kraken Plus 360 RGB’s advantages are mostly aesthetic. Yes, the Plus model performs better, but not by a huge margin.
