NZXT Kraken 360 PLUS CPU Liquid Cooler Review
Thermal Testing – Gaming
OC3D CPU Cooler Gaming Test
With this new CPU testing rig, we wanted to experiment with analysing the “gaming” performance of CPU coolers. After all, all-core stress tests are not a common workload for most PC users. Games do not usually put huge levels of stress on all cores of your processor, especially if your CPU has a high core count. We also wanted to see if your choice of CPU cooler impacts GPU thermals under a GPU-focused stress test. After all, your CPU cooler can have a huge impact on the overall airflow pattern of your PC.
This testing procedure uncovered something. What we found was that AIO CPU liquid cooling solutions gave us lower GPU thermals. This makes sense, as these solutions pump hot air directly out of our test system and act as an exhaust. That said, the impact on GPU thermals was minimal. We only saw drops of 2-3 degrees during this test. Given this lack of difference, we will now focus exclusively on CPU thermals with this test.
For our CPU game test, we used Final Fantasy XIV Endwalker’s benchmarking tool for our gaming test. This test can run for a long time and moves between CPU and GPU-limited parts of the game. This test was used at a resolution of 1080p at maximum settings.
1,000 RPM Fan Speed Test
Our gaming test is the less demanding of our two main thermal tests. It doesn’t max out all CPU cores, so this workload is far from the most stress we can put on CPU coolers. Even so, gaming is a workload that is worth testing. After all, that’s what a lot of people use their PCs for. For this scenario, the Kraken Plus 360 RGB performs well, sitting towards the bottom of our performance charts, which is a good thing as lower CPU temperatures are better.
In this test, the Kraken Plus 360 did notably better than the Kraken Core 360. We also tested the Plus 360 at 700 RPM, but noted a significant drop in cooling performance. Clearly, this cooler’s fans run optimally at higher speeds.
1,500 RPM Fan Speed Test
At 1,500 RPM, we see a further drop in CPU thermals, though the performance gap between the Kraken Core 360 and Kraken Plus 360 RGB has narrowed.
Max Fan Speed Test
At this unit’s maximum fan speeds, we see a further drop in CPU thermals, but the Kraken Core 360 delivers an identical CPU delta temperature. Both coolers are on par at their maximum fan speeds.
