NZXT Kraken 360 PLUS CPU Liquid Cooler Review
Solid performance with a solid feature set
NZXT has created an attractive package with its Kraken Plus 360 RGB. It delivers strong cooling performance, RGB fans, and even includes an LCD screen. It’s also easy to use, with pre-applied thermal paste and minimal cable management. Four cables and you’re finished! That’s a solid package for £134.90.
The only real criticism that you can level at the Kraken Plus 360 RGB is that its LCD is small at only 1.8 inches. That said, NZXT and other brands offer larger LCD screens if you want to pay more. This is a more budget-oriented CPU cooler; not a premium “my LCD is bigger than yours” cooler.
For its asking price, this cooler offers solid thermal performance. While it doesn’t offer the best performance we have seen, it delivers strong results at this price point. This means most users of this CPU cooler should be satisfied. That said, this cooler doesn’t push much past NZXT’s budget-oriented Kraken Core 360 in most of our tests, making it the best-value cooler in NZXT’s CPU cooling lineup. That said, it lacks RGB lighting and an LCD screen, which are sought-after add-ons. The core 360 also lacks a white version, so it isn’t an option for white PC builds.
What do you want from your next CPU cooler?
After reviewing NZXT’s Kraken Core 360, it becomes clear that RGB lighting and LCD screens come at a cost. By cutting down on complexity, NZXT delivered a CPU cooler that offers users exceptional value for money. With the Kraken Plus 360 RGB, we get an upgraded pump (Asetek Gen 9 vs Gen 9V), RGB fans, and an integrated LCD screen. When it comes to cooling, the benefits are small, but nonetheless present. However, it would feel wrong not to say that the primary benefits of the Kraken Plus 360 RGB over the Kraken core are aesthetic. We get flashy lighting with this unit’s RGB fans, and we get customisation with its LCD screen. We also get options, as the Kraken Plus is available in Black and White.
This cooler makes us question what we want from our CPU coolers. Do we want a product purely focused on CPU cooling, or something more customisable and aesthetically pleasing? If you want a pure CPU cooler at a lower price, NZXT’s Kraken Core 360 may be a better fit. That said, if you want an LCD-clad CPU cooler with RGB lighting that delivers solid cooling performance at a low price, the Kraken Plus 360 RGB ticks all of those boxes.
NZXT’s Kraken Plus 360 is well worth considering. It delivers solid thermal performance and strong aesthetics.
Join the discussion on NZXT’s Kraken Plus 360 RGB on the OC3D Forums.
