Alphacool Eisbaer LT 240 Review
The last time we looked at an Alphacool AIO was when we looked at the original Eisbaer 240 when we did the last Mega Test way back at the beginning of 2017. With that in mind we figured that we it was about time we had a look at the latest incarnation of the Eisbaer, the LT 240. Superficially the new model appears quite similar to the older model, save that the bulky cold plate.reservoir assembly has been replaced by a more compact and traditional looking cold plate. For the rest of the updates, best we have a look at the Technical Pecification
Technical Specification
| Intel | 775, 115x, 1366, 201, 2011-3, 2066, 604, 771 |
| AMD | AM2/, AM3/, AM4, FM1,2/ C32, G34, 754,939,940 |
| Radiator Size | 270X120X25MM (LxWxH) |
| Radiator Material | Copper |
| Tubing | PVC, 32mm long, 11/8mm with anti kink coils. |
| Fans | 2x120mm 550-1700RPM |
| Static Pressure | 1.66mmH20 |
| Airflow | 63.85cfm |
| Noise | 29dB(A) |
