Antec P183 Advanced Super Mid Tower
• No power supply included
• Power supply option: comes with a power supply mounting adapter to mount either a standard size power supply or Antecs exclusive CP Series power supply
• Innovative three-layer, sound-deadening side panels and front door (aluminium, plastic, aluminium) dampen noise and ensure Quiet Computing™
• 11 drive bays
– External 4 x 5.25″; 1 x 3.5″
– Internal 6 x 3.5″ for HDD
• Cooling system:
– 1 rear (standard) 120mm x 25mm TriCool™ fan
– 1 top (standard) 120mm x 25mm TriCool™ fan
– 1 lower front chamber – 120mm fan (optional)
– 1 upper front chamber – 120mm fan (optional)
– 1 middle chamber – 120mm fan (optional)
• Cable organisers behind motherboard tray minimise cable clutter
• Front-mounted ports provide convenient connections:
– 2 x USB 2.0
– 1 x eSATA
– Audio In and Out (HDA and ACÂ’97 compatible)
• Double hinged door opens up to 270?/li>
• 7 expansion slots
• 0.8mm cold rolled steel chassis for durability
• Compatible Motherboards: Mini-ITX, microATX, Standard ATX
• Case dimensions:
– 20.25″(H) x 8.1″(W) x 19.9″(D)
– 514 mm (H) x 205 mm (W) x 507 mm (D)
• Net weight: 30.9 lbs / 14 kg
