Cooler Master HAF Stacker System Review
The Build continued
With all the kit in the various elements of the HAF Stacker system the front panels are clipped back on with ease. In the images below we’ve filled the top 915R with 9HDD bays, whist at the same time building a standalone M-ITX based case into the lower 915F in total the whole system has rack space for 12 3.5/2.5″ drives in the racks with another 2.5″ drive mount posterior to the motherboard. There are 5×5.25″ bays, which if you chose can also double up as 3.5″ bays
Of course just because the drive bays are there doesn’t mean you have to use them. If you’re planning a water ccoling build with epic radiator capacity all you have to do is whip them out to make room for your rads. Below we’ve relocated the cages back into the main section to leave the upper 915R free and empty.
