Corsair 500R Review
Corsair Carbide 500R Review
Corsair 500R Review
There is something about white Corsair products that makes us go all fuzzy and warm, that mix of build quality and the subtle sexiness that a splash of white can provide (keep it clean). So with a warm fuzzy feeling not being caused by Emma Willis for once we finally get to take a look at the Corsair Carbide 500R.
Corsair 500R Review
Video Review
First things first, when we looked up the price of the 500R we thought there was a mistake as its priced at just £86. All of us here thought it would easily be around the £100 mark, its not very often a Corsair products leaves us thinking "OMG that's cheap"
The 500R is essentially a 400R with a few tweaks, the outside has obviously had a face lift but the internal chassis is basically the same albeit it now has removable hard drive bays. These similarities have some good and bad points, good in that the 400R was a great case with great cooling and plenty of room to build a tidy rig. The bad point is pretty much everyone we have spoken to has been excited about water-cooling this and thought that radiator support was the main point of this over the 400R. Sadly from a bolt it straight in point the only useful radiator you will be bolting in this is the H100 because that's what's its been designed for almost to the MM. No useful sized (50mm+) radiators will be able to be fitted in the roof without not refitting the black mesh panel.
The side panel comes fitted with a clear 200mm fan that has white LEDS which is something the 400R didn't, the side panel does still support 2x 120mm fans or 2x 140mm fans should you wish to change them. It's also worth noting thanks to the bulge in the side panel that the fans should clear almost all heatsinks, having the NH-D14 in and side panels fans is not a problem for example. The mesh on the side panel is great for people wanting to pummel their rigs with 1000's of CFM's of air but there are some of us that actually like to look at what we have invested our hard earned cash into, so a window panel would have been a nice option here and it does seem a shame this wasn't thought of.
So no watercooling support and no window yet it still got gold? Right this is where I break ranks from the normal reviews and slide in a bit of the old school TTL. If you whiz out the HDD bays and maybe Dremel out a chunk of the optical bay you should be able to fit a 240mm radiator (easily 60mm thick with push pull) you will have to remove a section at the front of the case and mount the rad with a radiator grill so you have something to bolt to the case and also fit the rad to but its easily done with a few hours and the right tools. Same with the window panel, you can remove the tabs where the mesh mounts to the side panel with a Dremel, layer up some double sided foam tape and you can fit some acrylic there and still have the nice recess making it look like a factory fit! I'm not going to go into every last detail but its 100% able to be done if you have the tools and know which end of a Dremel is which!
The long and short of it is the 500R is a great case for the money out of the box and 90% of you will be perfectly happy with what gets delivered. The other 10% of you can get your tools out and make yours unique with minimal effort and claim those all important e-peen inches over the stock case boys! Its been a long time coming but thank you Corsair, for your efforts we can Award the 500R the first Gold award since we reviewed the white 600T!
   Gold award
Thanks to Corsair for the sample we tested here today, you can discuss your thoughts of the review in our forums.
«Prev 1 Next»
03-11-2011, 04:51:48
Nice to see a decently priced case from Corsair. Nice review TTL Quote
03-11-2011, 05:46:00
A very nice case for the price and it look's the dog's danglie's as well .Quote
03-11-2011, 09:35:19
if this is gold i think it may be time for an oc3d platinum award???
extreemly flexible....(not in a good way)
mesh window ONLY
no real options for custom watercooling...
looks good tho......
and comes in white....
bronze with a value award or silver alone at bestQuote
03-11-2011, 09:35:34
how do you completely erase a dbbl post?????Quote
03-11-2011, 10:10:23
Originally Posted by badtaylorx View Post
Yeah I was a touch surprised with the Gold Award as well, but thinking of other reviews I think it's still consistent.
Though there doesn't seem to be a set-in-stone standard for review awards, there is definitely some method in the madness (sorry about semi-OT)Quote
