Corsair Carbide SPEC 01 & 03 Review
We all know that Corsair make some of the best cases on the market, we also know that they do “High End” extremely well. What has perhaps been missing from their world dominating line up though is a decent value for money gaming case. Enter then the Spec-01. It’s so tempting to tell you here and now just how feature packed this case is, but you know what, you’re just going to have to read the review. For now let’s just say that you won’t be expecting it to offer as much as it does, and especially for the £40 Corsair say it will retail for.
Technical Specification
| Dimensions | 428x200x447mm (HxWxD) |
| Material | Steel with Plastic front cover |
| 3.5″ | 4 |
| 2.5″ | 4 (shared with 3.5″) |
| 5.25″ | 2 |
| Expansion slots | 7 |
| Motherboard | ATX, M-ATX, M-ITX |
| Front I/O | 1xUSB2.0, 1xUSB3.0, Audio |
| Cooling |
Front: 1x120mm, 1x120mm optional Rear: 1x120mm Optional Roof: 2x120mm Optional |
| Max GPU length | 420mm |
| Max CPU Cooler Height | 153mm |
| PSU | ATX up to 200mm |
