Corsair Graphite 230T Review
We’re not sure whether you can use the term “series” with regards to PC cases if there’s only one case in the “series”. You see up to now the 600T has been more than a little lonely being as it was the only member of the Corsair Graphite series. We say was as it now has some company in the form of the new Graphite 230T. A mid tower case aimed quite squarely at gamers the 230T has striking lines, and if you opt for the Orange featured in the review sample quite striking colours too. Should you fancy something a little more subtle you could always opt for the more classic Black or slightly avant-garde Grey. Each of the cases comes complete with 3x120mm fans, the front two of which are LED units intended to compliment the tone of the case.
| Dimensions | 550x210x440mm LxWxH |
| Weight | 6.16kg |
| 2.5″ bays | 4 |
| 3.5″ bays | 4 |
| 5.25″ bays | 3 |
| Cooling |
Front 2×120 LED included Rear 1×120 included Roof 2×120 or 2×140 Optional Base 1×120 or 1×140 Optional |
| Compatibility | ATX, mATX, Mini ITX |
| Expansion slots | 7 |
| Max CPU Cooler Height | 160mm |
| Max GPU Length |
430mm Top slots 320mm Lower slots |
