Fractal Define R6 Review
It’s been a while since we’ve reviewed a Fractal case, but boy has it been worth the wait, as up for review today we have the brand new Define R6.  On the surface it might not look that special, but delve inside it’s cavernous interior and we think you’ll find it’s pretty well thought out.  If you don’t like the model we have here then you’ll be delighted to know it comes in Black, Blackout, White, and Gunmetal, with or without the tempered glass side panel.  Is it the perfect case?  Will it be taking the case crown?  To be honest if first impressions are anything to go by, there’s a chance it might.  If you want to learn more then best you read on, starting as always with the all important Technical Specification
Dimension (Approx) 543x233x465mm (LxWxH)
Motherboard Support  E-ATX (up to 285mm wide) ATX, M-ATX, M-ITX
5.25″  1
3.5″  6 (option of 2 stealth mount)
2.5″  10 (6 shared with 3.5″)
Air Cooling
Front:   2x140mm, 3x120mm (2x140mm included)
Roof:    3x140mm, 3x120mm
Rear:    1x140mm, 1x120mm (1x140mm included)
Floor:    2x140mm, 2x120mm
Water Cooling  Front:    Up to 360mm, 280mm
Roof:     Up to 360mm, 420mm
Rear:    120mm
Floor:    Up to 280mm, 240mm
Max PSU Length  300mm
Max GPU Length  465mm
Max CPU Cooler Height  185mm
Front I/O  Power, Reset, HD Audio, 2xUSB 3.0, 2xUSB 2.0
Expansion Slots  7 (+2 vertical)
Key Features
Full-size seamless scratch-resistant tempered glass side panel (Tempered Glass Version Only)
Optimized for silence with high-density industrial dampening on side, top and front panels
Reversible front door with anodized aluminum cover and dual mounting system for adaptability with elegance
Nine fan positions with intuitive layout and clear airflow paths offer massive cooling capacity
Nexus+ Smart Hub offers superior fan control of six additional case fans and three extra PWM devices via your motherboard.
Three silent, airflow-optimized Fractal Design Dynamic X2 GP-14 140 mm fans come pre-installed helping ensure superior airflow via two intake fans and a single exhaust.
Extensive water cooling support with room for up to a 420 mm radiator in the top, 360 mm in the front, and up to 280 mm in the base
Power supply shroud and Modular Storage Plate conceal HDD trays and excess cabling for a clean, clutter-free interior
Third generation ModuVent™ technology gives users the choice between a soundproof steel cover or filtered multi-fan ventilation setup in the top panel
Easy-to-clean high airflow nylon filters on the front, top, and base with full PSU coverage and front access for convenience
Modular Storage Plate lets users easily convert between the Standard Layout for maximum storage capacity or the new Open Layout for superior water cooling support and clear air flow paths
Vertical 2.5 slot GPU mount, compatible with the Fractal Design Flex VRC-25 PCIE x16 Vertical GPU Riser Kit, showcases your graphics hardware with full visibility and secure fastening (sold separately)
Highly modular interior includes six universal SSD/HDD trays that can be independently repositioned to suit components, cooling, and cable routing
Customizable 2.5” storage solution consists of two brackets and a choice of four tray locations to keep drives hidden behind the motherboard tray or display them prominently on top of the PSU shroud
Compatible with Fractal Design Connect D1 USB 3.1 Gen 2 Type-C Upgrade Kit for ultra-fast file transfers and fast charging (sold separately, requires a compatible motherboard)
