NZXT H510 Elite Review
If you’ve been following the rollout of the 500 series from NZXT you might have been expecting the appearance of a “flagship” model. If you were, then the H510 Elite might just be it. If, however, this isn’t your first rodeo, you might be suspicious that NZXT has simply bolted on a few extras and pumped up the price. Well, that’s where we come in. So is this a true Luxury model, or just a bog-standard “L” model with a few tweaks and a bit of extra trim? best we have a look at the tech specs to see what can be learned there.
Technical Specification
| Dimensions | 210x460x428 mm (W x H x D) |
| Material | Steel Chassis, Tempered glass panels |
| Weight | 7.5kg |
| Motherboard | M-ATX, ITX ATX, |
| 5.25″ | 0 |
| 3.5″ | 2 + 1 |
| 2.5″ | 2 + 1 |
| Front I/O | 1xUSB Gen 3.1 Gen 2 type C, 1xUSB 3.1 Gen1 Type A, !x Headset Audio Jack (adapter supplied) |
| Expansion Slots | 7 horizontal + 2 vertical. |
| Air Cooling |
Front: 2x140mm, 120mm (2x AER RGB 140mm included) Roof: 1×120/140 Rear: 1×120 (1×120 non rgb included) |
| Water Cooling |
Front: 240mm Roof: N/A Rear: 120mm |
| Max CPU Cooler Height | 165mm |
| Max GPU Length | 368.5mm |
| Max PSU Length | Not confirmed but up to at least 170mm |
