Prolima Tech Vortex Fan Review Round Up
It’s no coincidence that ProlimaTech, well known for their range of performance CPU and VGA cooling solutions, should also produce a range of fans. Here we take a look at the entire Vortex range, including the rather sexy looking Aluminium bladed 140mm model. With the exception of the Aluminium model which comes fitted with red LEDs as standard, ProlimaTech offer 2 sizes and 3 finishes to the range, with both the 120mm and 140mm fans available in plain red, plain blue, LED red and LED blue. On paper the fans offer high CFMs with varying dB-A ratings. Lets look at the full tech spec for a better idea of what we have on offer to us.
Specifications
120 Vortex
Dimension |
(L)120mm X (W)120mmX (H)25mm |
Bearing Type |
Sleeve bearing |
Rated Voltage |
12 VDC / 9 VDC |
Operating Voltage Range |
6~13.8 VDC |
Rated Current |
0.18 Max.Amp |
Rated Power |
2.16 Max.Watt |
Rated Speed |
1600 RPM / 1200 RPM |
Airflow |
72.67 Max.CFM |
Noise Level |
29.1 dBA |
Net Weight |
138.2 Gram |
Connector |
Terminal Connector(3-pin plus 4-pin molex) |
120 Vortex LED
Dimension |
Bearing Type |
Sleeve bearing |
Rated Voltage |
12 VDC / 9 VDC |
6~13.8 VDC |
Rated Current |
0.3 Max.Amp |
Rated Power |
3.6 Max.Watt |
Rated Speed |
Airflow |
72.67 Max.CFM |
Noise Level |
29.1 dBA |
Net Weight |
107.2 Gram |
Connector |
LED |
Blue/red |
140 Vortex
Dimension |
(L)140mm X (W)140mmX (H)25mm |
Bearing Type |
Sleeve bearing |
Rated Voltage |
12 VDC |
7~13.8 VDC |
Rated Current |
0.2 Max.Amp |
Rated Power |
2.4 Max.Watt |
Rated Speed |
1000±100RPM |
Airflow |
87 Max.CFM |
Noise Level |
18.1 dBA |
Net Weight |
162 Gram |
Connector |
140 Vortex LED
Dimension |
Bearing Type |
Sleeve bearing |
Rated Voltage |
12 VDC |
7~13.8 VDC |
Rated Current |
0.2 Max.Amp |
Rated Power |
2.4 Max.Watt |
Rated Speed |
1000±100RPM |
Airflow |
87 Max.CFM |
Noise Level |
18.1 dBA |
Net Weight |
162 Gram |
Connector |
LED |
Red/Blue |
140 Aluminium
Dimension |
Bearing Type |
Two Ball bearing |
Rated Voltage |
12 VDC |
7~13.8 VDC |
Rated Current |
0.45A |
Rated Input Power |
5.4W |
Rated Speed |
1600RPM/1200RPM/900RPM |
Airflow |
127CFM/100CFM/65CFM |
Noise Level |
28dBA/20dBA/15dBA |
Net Weight |
152g |
LED |
Red |
Accessories |
Fan Screw*4 3;4-Pin Adapter*1, |
