SilverStone FN and FW Series fans Review
Never one to hang about Silverstone have added to their already extensive range of fans by augmenting the FW and FN series. Here we’re going to take a look at the FW121, the FW122 and the FN123. Although they might be numbered concurrently, there are significant differences between them. In simple terms the FW121 is a slim PWM fan with white blades and a blue cowling, the FW122 is a standard thickness PWM fan with white blades and a blue cowling and the FN123 is a slim non PWM fan with White blades and a Black cowling. With us so far? No? Then best we have a look at the full technical Specification.
Technical Specification
FW121
Model No. |
SST-FW121 |
Color |
White fan blades, blue frame |
Bearing |
Long life sleeve |
Connectors |
4pin PWM |
Rated Voltage |
12V DC |
Start Voltage |
5V DC |
Rated Current |
0.02 ~ 0.09A |
Rated Power |
0.24 ~ 1.08W |
Speed |
800 ~ 2000 rpm |
Airflow |
13.1 ~ 32.6CFM |
Static Pressure |
0.31 ~ 1.52mmH2O |
Noise Level |
14.7 ~ 24.6dBA |
Life Time |
40,000 hr |
Dimension |
120mm (L) x 120mm (W) x 15mm (H) |
Weight |
109g |
FW122
Model No. |
SST-FW122 |
Color |
Bearing |
Long life sleeve |
Connectors |
4pin PWM |
Rated Voltage |
12V DC |
Start Voltage |
5V DC |
Rated Current |
0.07 ~ 0.19A |
Rated Power |
0.84 ~ 2.28W |
Speed |
1000 ~ 1800 rpm |
Airflow |
42.6 ~ 76.5CFM |
Static Pressure |
0.31 ~ 1.52mmH2O |
Noise Level |
18.4 ~ 28.1dBA |
Life Time |
40,000 hr |
Dimension |
120mm (L) x 120mm (W) x 25mm (H) |
Weight |
130g |
FN123
Model No. |
SST-FN123 |
Color |
White fan blades, black frame |
Bearing |
Long life sleeve |
Connectors |
3pin |
Rated Voltage |
12V DC |
Start Voltage |
5V DC |
Rated Current |
0.16A |
Rated Power |
1.92W |
Speed |
2000 rpm |
Airflow |
32.6CFM |
Static Pressure |
1.52mmH2O |
Noise Level |
23.5dBA |
Life Time |
40,000 hr |
Dimension |
Weight |
112g |
