Thermaltake wowed us with their MAGFloe AIOs at CES
Let’s have a look at Thermaltake’s newest AIOs and fans
OC3D is at CES 2025, and we have spent a lot of time at Thermaltake’s booth. Simply put, they had a lot of products to show us, from cases to coolers and even racing sim equipment. In this article, we will be looking at their latest cooling solutions, specifically their MAGFloe and MAGCurve series AIO CPU liquid coolers.
Meet the Thermaltake’s high-end MAGCurve AIO Liquid Coolers
On the high end of Thermaltake’s liquid cooling lineup is their new MAGCurve series of AIOs, which feature a 6.67-inch AMOLED curved screen. This CPU liquid cooler is available in black and white; below, you can see this cooler’s 360mm versions.
The versions below feature Thermaltake’s SWAFAN EX12 ARGB fans, which use MAGFAN 2.0 connections. This means that all three fans are powered by a single cable, making cable management a breeze.
Below you can see the curve of this cooler’s AMOLED screen in action. This screen can be used to display many different types of content. This screen can be controlled using Thermaltake’s TT RGB Plus 3.0 software.
Thermaltake has also experimented with different colour schemes for these new CPU coolers. Below, we have the company’s Bumblebee (Yellow) and Gravel Sand options. Remember that Thermaltake has cases that are available in these colours.
Gorgeous screens on the Thermaltake MAGFloe series
Next up we have the Thermaltake MAGFloe 360 Ultra series of ARGB liquid cooling solutions. These coolers also use pre-installed SWAFAN EX12 ARGB fans. However, unlike the MAGCurve, the MAGFloe has a smaller, non-curved LCD screen.
Note that this screen is 3.95 inches in size, and is borderless on three sides.
Thermaltake TOUGHFAN EX12/14 and TS120/140 EX fans
Moving onto fans, below we have the TOUGHFAN EX12/14 series of ARGB fans. These fans are available in black and white and have RGB LEDs integrated into their frames. TOUGHFAN EX12/14 fans can be daisy-chained and attach to each other using Thermaltake’s “MagForce 2.0” technology.
These fans are available in 3-fan packs and use the same fan design as Thermaltake’s TOUGHFAN series.
Next we have the TS120/140 EX RGB fan series. Like the TOUGHFAN ARGB fans above, these fans are available in 3-fan packs and in 120mm and 140mm forms. These fans also feature RGB lighting but implement it differently. These fans have an RGB-illuminated ring around their blades and illuminated elements at each fan’s edges.
Thermaltake’s new TS120/140 EX RGB fans feature daisy-chain support. Each fan connects together using Thermaltake’s MagForce 2.0 technology. Note that all of these fans are PWM-controlled. Furthermore, the lighting of these fans is controllable using motherboard RGB Sync software solutions.
We have other articles on Thermaltake’s presence at CES 2025. You can have a look at their PC cases here, and their Racing Sim/Flight Sim products here.
You can join the discussion on Thermaltake’s newest CPU coolers and fans on the OC3D Forums.
