Thermaltake DH 104
Since the beginning of Thermaltake in 1999, it has been at the forefront of creating new and exciting products at a time where most computer users were provided little to no choices for components that may seem irrelevant, but in reality crucial to the performance of a PC.
With its comprehensive line of products available, it enables Thermaltake’s core customers to enjoy a one-stop-shop experience, reduce product design-in evaluation period and most important of all, flawless integration process. Each of Thermaltake’s strengths enables its customer to focus on their core business while taking advantage of the skills and efficiency of a single thermal management solution partner.
Case Type: Home Theater Media PC
Dimensions: (H x W x D) 211 x 464 x 430 (8.31 x 18.27 x 16.93 inch)
Net Weight: 10.8 kg / 23.78lb
Color: Black
Material: Panel– Al / Body- SECC
Cooling System: Front– 120mm fan x 1, 1300rpm Rear– 120mm fan x 1, 1300rpm
Drive Bays: External 5.25” x 1 Internal – 3.5” x 5
Expansion Slots: 7
Motherboards: ATX & Micro ATX form factor
Media Kits: Built-in all new revolutionary 7” touch screen hot keys module
Front I/O: USB 2.0 x 2, IEEE 1394 Firewire, HD-Audio
