TRYX Panorama ARGB 360 CPU Cooler Review
Up Close with the TRYX Panorama 360 ARGB
Up close with he TRYX Panorama 360 ARGB
Overall, the Panorama is packaged neatly and in a way that makes installation a breeze. All of the cooler’s fans are pre-installed. All users need to do is install the correct brackets, place it in their systems, and wire it up. Simples!
The TRYX Panorama has a large water block. The size of this block is mostly to do with its large L-shaped screen, and below, we can see ventilation holes for the block’s integrated fan.
Below, we can see the L-shaped AMOLED screen of the Panorama. This is the centrepiece of this CPU cooler, providing it with a WOW factor that no other heatsink can match.
Below, you can see that this AIO’s screen can be removed and replaced with ease. It is attached magnetically to the rest of the cooler, allowing users to see the fan below. This makes cleaning and maintenance an easy process.
The liquid cooling radiator is 30mm thick. TRYX has also fitted this radiator with high-density fins, and uses tubing that is 40% thicker than many competing coolers. TRYX has done what it can to increase coolant flow and maximise heat dissipation.
Below, we can see this cooler installed in our Intel LGA1700 test system. Out of the box, the screen is stunning, and its pseudo-3D effect is mesmerising.
