AMD Phenom II X4 965 BE
3D Gaming Results
Crysis
Crysis is without doubt one of the most visually stunning and hardware-challenging games to date. By using CrysisBench - a tool developed independently of Crysis - we performed a total of 5 timedemo benchmarks using a GPU-intensive pre-recorded demo. To ensure the most accurate results, the highest and lowest benchmark scores were then removed and an average calculated from the remaining three.
Call of Duty 4: Modern Warfare
Call of Duty 4 is a stunning DirectX 9.0c based game that really looks awesome and has a very full feature set. With lots of advanced lighting, smoke and water effects, the game has excellent explosions along with fast game play. Using the in-built Call Of Duty features, a 10-minute long game play demo was recorded and replayed on each of the GPU's using the /timedemo command a total of 5 times. The highest and lowest FPS results were then removed, with an average being calculated from the remaining 3 results.
FarCry 2
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning "world", "earth" or "living" in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
RaceDriver GRID
Results Analysis
As usual, the 965 loses out to the 920 here in Crysis and Far Cry 2 due to the support for multiple cores. The 965 does edge away in GRID however with it's higher clock. All 4 processors do deliver frame rates that are acceptable however, all very close to 60FPS.
«Prev 1 2 3 4 5 6 7 Next»
17-08-2009, 11:07:54
FarFarAway
A predictable outcome, but a step in the right direction none-the-less. I keep getting tempted to pick up an AMD CPU just for the sheer hell of it, but other stuff tends to get priorities
Good review Quote
17-08-2009, 11:09:58
mayhem
Well thought out set of phrases.
Nice review all though the cpu is not just yet my cup of tee, how ever i will sing a song of Boom Boom Boom Let me way Eh Oh !!!!!! Or was it just a fizz and pop when it blew
nice to see you pushing it to its own demise .. are you going to get a new sample to play with.Quote
17-08-2009, 12:00:30
JN
Really hoping so as 4.1GHz felt achievable even on the basic Gigabyte board that was used. Even more interesting than the max oc will be what results it gets at 4-4.1ghzQuote
17-08-2009, 12:04:21
Mul.
It was very unfortunate that it bit the dust so prematurely. I was surprised because I and many others have pushed AMD Phenom II CPU's past 1.50V on air without any sign of it causing any damage. Overclocked performance would have been something particularly interesting to see as I've found that these processors scale rather well with clock speed increases especially with ramped up northbridge frequencies and DDR3. As I mentioned before, it's also quite well known for the Phenom II to overclock as much as 200MHz less on a 64bit operating system than on a 32bit OS.Quote
17-08-2009, 14:45:50
Rastalovich
It's a little more unfortunate that the E8400/ROG-P45/DDR2 was used as the C2D comparison.
Not that it'd obviously stake any claims to outperform anything, but mentioning a Q9550 - that would have been nice. And a X48 DDR3 sporting mobo too, atleast a P45 DDR3 - particularly when emphasis is made on artificial benchmarks.
I personally see 775 as still a viable option.Quote
