ASUS TUF B550M-Plus WiFi Review
Test Setup
As well as the B550 motherboards we’re also including our X570 motherboards in our graphs today, just to demonstrate how little the ‘lesser’ AMD Chipset is giving up compared to its bigger brother. Perfect if you’re on a tight budget.
AMD Ryzen 9 3900X
G.Skill Trident Z 3600 MHz
Corsair Vengeance RGB 4600 MHz
Corsair MP500 M.2 – OS Drive
Aorus PCIE4 NVME – Storage Speed Tests
Nvidia RTX 2080Ti
Corsair HX1000i
Corsair H150i
Corsair ML Fans
Overclocking
So far we’ve had some pretty high end motherboards to work with and they’ve all squeezed 4.4 GHz from our test Ryzen 9 3900X. The Strix-F and MSI Mortar topped out at 4.35 GHz and the TUF Plus continues that trend of the more affordable options not quite getting everything from our CPU, even if 50 MHz a thread is hardly a massive disparity. Our results will show how much, so let’s get down to some benchmarking.
