ASUS ProArt Z690 Creator WiFi review
AIDA64
Since its early days as Everest, AIDA64 has provided an excellent way to benchmark your system without requiring you to take a week off work whilst the tests run. From the memory bandwidth benchmarks which test your throughput, to the CPU benchmarks which vary in scope to test everything from raw calculation â CPU Queen â through compression algorithms â zLib â and the all important encryption â AES256.
Itâs worth bearing in mind that the TUF and Strix results are obtained utilising DDR4, so naturally the memory has better latency but worse overall throughput.
