ASUS Rampage 4 Extreme Review
wPrime95
If CPUs get much faster we’re going to need a separate graph to make the 32M result wider than a pixel. It’s a very close run thing between the two mightiest Intel CPUs, but the i7-3960X just shades the i7-990X. 2 minutes to run a 1024M wPrime95 test.
x264 Benchmark
The beast is unleashed. Generally speaking the improvement you get from an overclock is fairly linear. The faster your CPU is the higher your result will be. This is most definitely not the case with the i7-3960X and Rampage IV Extreme combination as our overclock sprints off into the sunset like a thoroughbred over the final furlong.
