DFI Lanparty T3eH6 DK X58 Motherboard
HDTach is a free hard disk benchmarking program from SimpliSoftware. This benchmark is not only capable of producing results on hard disk access times but also CPU usage required during disk access. The “Long bench” was run a total of 5 times with the highest and lowest results being omitted and an average calculated from the remaining 3 results.
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Results Analysis
Yet again, the DFI could not separate itself from it’s competitors. It’s best result of the day came in the Sandra Read speed, finishing in Pole position however in the same test, HDTach showed it to be the worst performer.
Let’s see how the motherboard performs with our multimedia benchmark suite…
