Gigabyte EP45-UD3P (P45) Motherboard
ViMark is the latest addition to the OC3D motherboard testing process and a relatively new benchmarking application in general. Designed to take the inaccuracies and guesswork out of measuring the time taken to encode video files, ViMark produces easily comparable and consistent results for encoding raw video into Windows Media, Quicktime, AVI and Gif formats. As always, a total of 5 benchmark runs were performed with the highest and lowest scores removed and an average calculated from the remaining 3 scores.
7-Zip is an open source Winzip-style file compression utility that has the ability to compress and decompress many file formats including its own .7z compression scheme. 7-Zip also comes complete with its own benchmarking utility for gauging the compression and decompression speed of the system that it is installed on.
Results Observations
Pretty much a mixed bag of results was to be had in the media encoding benchmarks, with the UD3P scoring high in some and low in others. The UD3P did, however, once again match the EXTREME in the majority of tests, which I predict will be the same for our hard drive benchmarks…
