Gigabyte EP45-UD3P (P45) Motherboard
It was with some trepidation that I began reviewing the UD3P, as initially, with the state the box arrived in, I was surprised that the board would even boot! Luckily, it did and the first set of benchmarks set the stage for what I assumed to be an identical run of scores to that of its much more expensive stablemate, the EP45 Extreme. However, once we were past the memory benchmarks, I was constantly impressed by the way this budget board performed. Getting the upper hand of motherboards costing twice as much is no easy feat, but the little Gigabyte board managed it without so much as breaking a sweat.
Although the overclocking results were good, I was a little disappointed as I really wanted this board to perform above the other boards based on the same chipset. While it didn’t disgrace itself, I am beginning to feel that the new range of boards are being held back by the older 65nm chips we use for our tests and believe the new range would be much more suited to the high FSB Wolfdale clockers. 500FSB is about the max anyone could expect of a Quadcore CPU based on the 65nm architecture, but there are dual core CPU’s reaching 600MHz these days with just a few minor voltage adjustments. So while the UD3P scored well in the overclocking department, I would have no doubts in believing it can be pushed quite a bit further given a decent dual core CPU.
The 3D benchmarks are where the GA-EP45 UD3P really stood out from the crowd. Consistently scoring high, at times outstripping boards costing double (including Gigabytes own EXTREME P45 board), the UD3P demands some serious consideration from any gamer wanting a last throw of the dice before i7 hits the shelves.
The Good
– Cooling
– 3D Performance
– The price
The Mediocre
– BIOS still ‘clunky’ to use
– Packaging could be improved
The Bad
– Nothing to report
