MSI Versa 300 Wireless 8K Mouse Review
Should you have investigated MSI mice before you’ll probably have come across their Forge models and their Clutch ones. More than a lot of their contemporaries, MSI design their products for things you need. Yes, they could go all in on making it weigh the same as a feather. Or cover the whole surface in a flexible OLED screen for customisation.
That isn’t their metier though. Instead they make sure that the reason for its existence has all the boxes ticked. Which neatly brings us to the newest model in their Versa range, the Versa 300 Wireless 8K. Wireless is the obvious part of that. What about 8K?
Well it isn’t the future resolution they mean. Instead the Versa 300 8K supports a 8000 Hz polling rate. If you’ve ever felt that your hardware was letting you down, and that a more responsive model would let you flex your skills, this is the mouse for you. Monstrous sensor. Light weight. Ultra responsive. If you just want your mice to be glitzy on the ‘Gram, then come this way to the egress. Should, however, you chiefly care about performance. Roll up roll up.
Versa 300 Wireless 8K Specifications
