Gigabyte EP45-UD3P (P45) Motherboard
Specification
The specifications below were unashamedly taken directly from the Gigabyte website.
CPU
- Support for an Intel Core™ 2 Extreme processor/ Intel® Core™ 2 Quad processor/Intel Core™ 2 Duo processor/ Intel® Pentium® processor Extreme Edition/Intel® Pentium® D processor/ Intel® Pentium® 4 processor Extreme Edition/Intel® Pentium® 4 processor/ Intel® Celeron® processor in the LGA 775 package (Refer to CPU support list for more information)
- L2 cache varies with CPU
Front Side Bus
- 1600/1333/1066/800 MHz FSB
Chipset
- North Bridge: Intel® P45 Express Chipset
- South Bridge: Intel® ICH10R
Memory
- 4 x 1.8V DDR2 DIMM sockets supporting up to 16 GB of system memory
- Dual channel memory architecture
- Support for DDR2 1366+/1066/800/667 MHz memory modules (Refer to Memory support list for more information)
Audio
- Realtek ALC889A codec
- High Definition Audio
- 2/4/5.1/7.1-channel
- Support for Dolby Home Theater
- Support for S/PDIF In/Out
- Support for CD In
LAN
- 2 x Realtek 8111C chips (10/100/1000 Mbit)
- Support for Teaming
Expansion Slots
- 1 x PCI Express x16 slot, running at x16
- 1 x PCI Express x16 slot, running at x8 (The PCIEx16 and PCIEx8 slots support ATI CrossFireX technology and conform to PCI Express 2.0 standard.)
- 1 x PCI Express x1 slot
- 2 x PCI slots
Storage Interface South Bridge:
- 6 x SATA 3Gb/s connectors (SATAII0, SATAII1, SATAII2, SATAII3, SATAII4, SATAII5) supporting up to 6 SATA 3Gb/s devices
- Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
Gigabyte SATA 2 Chip:
- 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
- 2 x SATA 3Gb/s connectors (GSATA2_0, GSATA2_1) supporting up to 2 SATA 3Gb/s devices
- Support for SATA RAID 0, RAID 1 and JBOD
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
IEEE 1394a
- T.I. TSB43AB23 chip
- Up to 3 IEEE 1394a ports (2 on the back panel, 1 via the IEEE 1394a bracket connected to the internal IEEE 1394a header)
USB
- Integrated in the South Bridge
- Up to 12 USB 2.0/1.1 ports (8 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors
- 1 x 24-pin ATX main power connector
- 1 x 8-pin ATX 12V power connector
- 1 x IDE connector
- 8 x SATA 3Gb/s connectors
- 1 x CPU fan header
- 2 x system fan headers
- 1 x power fan header
- 1 x front panel header
- 1 x front panel audio header
- 1 x CD In connector
- 1 x S/PDIF In header
- 1 x S/PDIF Out header
- 2 x USB 2.0/1.1 headers
- 3 x IEEE 1394a headers
- 1 x serial port header
- 1 x parallel port header
- 1 x chassis intrusion header
- 1 x power LED header
Back Panel Connectors
- 1 x PS/2 keyboard port
- 1 x PS/2 mouse port
- 1 x optical S/PDIF Out connector
- 1 x coaxial S/PDIF Out connector
- 2 x IEEE 1394a ports
- 8 x USB 2.0/1.1 ports
- 2 x RJ-45 ports
- 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
BIOS
1. 2 x 8 Mbit flash
2. Use of licensed AWARD BIOS
3. Support for DualBIOS™
4. PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Bundle Software
1. Norton Internet Security (OEM version)
Operating System
1. Support for Microsoft/ Windows/ Vista/XP
Form Factor
1. ATX Form Factor; 30.5cm x 24.4cm
Well the specification is certainly very thorough. Sadly, no onboard switches this time around, which will definitely be missed by overclockers, especially the CMOS reset switch. Hopefully the EP45-UD3 can recover from a bad overclock well!
Let’s head over to the next page where we will take a look at the motherboard itself….
