Gigabyte X670E Aorus Master Review
Test Setup
As always here at OC3D when there is a move to a new platform we have taken the opportunity to refresh both our test system and the things that we are using to benchmark. Naturally this means that some of our new tests will have fewer results than some of the others, but given how rapidly the market has moved forwards it’s fair to say that anything older than the last generation is going to be left in the dust. Clock speed only gets you so far after all. We’ve also rejigged our graphs a little after last time to hopefully make them more legible with less neck-ache. Don’t forget you can embiggen them.
AMD Ryzen 9 7900X
G.Skill Trident Z5 Neo 4800 32GB
Nvidia RTX 2080 Ti
Patriot Viper VP4100 NVMe
BeQuiet Silent Base 802 Case
BeQuiet Dark Power Pro 12 1200W PSU
BeQuiet Silent Loop 2 360
BeQuiet Silent Wings Pro Fans
Windows 11
Clock Speeds
The Aorus Master has some seriously high end hardware on its PCB and has no trouble at all keep our Ryzen 9 7900X running flat out. There is a lot of headroom too, should you wish to delve in to the world of manual overclocking, although we’ve already seen that the core scheduling and automatic boost technology works so well it’s almost better these days to just build and play.
