Intel Core i5-2405S Review
CineBench
CineBench is in the odd position of highlighting both the good and bad sides of the i5-2405S. In the CPU test it’s not quick. At all. When it comes to the OpenGL test it’s not quite as bad, but clearly there is only so much that the GPU can overcome.
Crysis Warhead
Nicely following our 3D Mark testing, Crysis Warhead shows that the Core i5-2405S can power our GTX570 along with enough oomph to maintain a perfectly good frame-rate. 60 FPS is more than plenty for anyone’s needs.
