MSI X470 Gaming M7 AC Review
Test Setup
AMD Ryzen 7 2700X
Corsair LPX 2666MHz
Corsair LPX 3200MHz
Corsair MP500 M.2
nVidia GTX 980
Corsair HX1000i
Corsair H110i GT
Corsair ML Fans
Overclocking
We have three different CPU-Zs to show you, demonstrating the flexibility of the MSI M7. Should you want to commit to having the fastest DDR4 speeds available then the M7 managed to push our DDR4 kit all the way up to 3800 MHz. An amazing amount of speed and showing how AMD have overcome one of the biggest weak links in the original Zen launch.
For our overclocked testing we’re combining the 3200 MHz DDR4 with 4.275 GHz on the Ryzen 7 2700X. This is a very meaty combination that should give us some eye-opening scores in our benchmark suite. It takes a little bit of voltage to achieve this, so make sure you have good cooling installed and don’t rely upon the Wraith Prism cooler.
If you’re one of those people who want nothing more than the absolute fastest overclock regardless of its 24/7 stability then the MSI Gaming M7 certainly will cause much appreciative nodding with its 4.475 GHz overclock. Hugely impressive and a good demonstration of what you can hope to achieve at the top end.
