NZXT Z370 N7 Motherboard Review
Test Setup
NZXT Z370 N7
Intel Core i7-8700K
Corsair LPX 4000MHz
Corsair LPX 3200MHz
Corsair MP500 M.2
nVidia GTX 980
Corsair HX1000i
Corsair H110i GT
Corsair ML Fans
Clock Speeds
Usually at this point we’d be showing you our overclocking results. Unfortunately whilst the N7 has got overclocking in the BIOS it is in a form which we are absolutely not keen at all on utilising on our glorious Core i7-8700K. The multiplier seems to be tied into the CPU VCore so that any changes are wholesale ones more akin to the old automatic overclocking options that fried so many chips in the old days rather than something which gives you infinite control to maximise performance whilst minimising heat and power draw. If ever you want to know the downside of using an OEM as your motherboard factory and draping your own elements on top, then this is a clear indication of the pitfalls of that system, whilst also clearly showing why the major manufacturers design their own motherboards.
All aboard the “stock results only” express then.
