Cooler Master GM2711S 180Hz 1440P Monitor Review
Up Close
Up Close
More than most items of hardware, packaging for displays is the kind of thing you keep around. Returning memory or processors is easy to find packaging for. Displays require their own dedicated box. It’s nice, therefore, that the GM2711S box isn’t larger than necessary and is plain cardboard for easy recycling once you’re past the warranty period.
From left to right we have a headset jack, USB-B to connect the Cooler Master GM2711S to your rig, Audio out jack, USB port, two HDMI 2.0s and a DisplayPort 1.4. Plenty of options.
The next two photos are useful for showing off two of the features of the Cooler Master GM2711S. You can bask in the glory of the 45° swivel. Perhaps enjoy the minimalist design of the base. Or, and this is where we show our multi-purpose images, just get a glimpse of how well the A.R.T works in eliminating reflections. Even our bright photographic lights are diffused so easily that you barely notice them. Perfect if your workspace is near a window.
As well as 90° rotation and 30° of tilt, the GM2711S has 130mm of total height adjustment. So whether you’re a jockey or a basketball player, you’ll find an ergonomically suitable position.
Here it is at its peak height. Comfy.
