Gigabyte GTX480 SOC Review
Up Close
Published: 22nd November 2010 | Source: Gigabyte | Price: £350est |
Looking a Little Closer
Following the success of its Dual-BIOS system on the Gigabyte motherboards we now have one on the GPU. In standard position we have the normal Super Over Clock BIOS, but a quick press shifts to a secondary BIOS that is dedicated to the extremist LN2 brigade and cures cold-start issues.
Beneath the main three heatsink areas is a vapor chamber connected via three pure-copper heatpipes. As we all know genuine vapor cooling and heatpipes are the best method for air-cooling thanks to the heat loss from changing the liquid to a gas and back again.
There is undeniably little likelyhood of any heat being trapped within the cards surround. Although obviously this does take us back to the problem of heat being dissipated into the case, but that's something which occurs with nearly every non-reference design on the planet.
Power phases cannot be underestimated when it comes to the importance of providing stability and performance with any chips and that's a quality that hasn't been lost on Gigabyte. The GTX480SOC comes equipped with twice the power-phases of the stock card, having 12+2 rather than the 6+2 of the nVidia original.
Wow it's a very nice job that Gigabyte has done. I'm wondering how their warranty and support will be for GPU's, if it's comparable to EVGA and they bring more non-reference cards like this well... They'll do really well! Comparing this card at stock the the reference card is quite impressive and the work Gigabyte put in, especially with technology that you can't pronounce ![]() |
