XFX 9600 GT XXX Alpha Dog Edition 740M 512mb
Test Setup
To test all of our GPU’s, we use a system that bottlenecks them as little as possible. Here’s the trusty test rig:
Intel Core2Quad Q6600 @ 3.6GHz
Hitachi 7K160 HDD
Samsung DVD-RW
Please note that we have set the overclock on the Q6600 to be able to keep our test setup fairly consistent as the speeds of CPU’s increase in the near future.
Benchmarks Used
Again, Overclock3D has revised it’s benchmark setup to really test the new DX10 GPU’s, while still including some old favourites in there:
Synthetic Benchmarks
Please note all Synthetic benchmarks were run at stock settings; just as the free ones would be, as well as 1920 x 1200, with 4 x AA added. All benchmarks are repeated three times for consistency.
FutureMark 3DMark03
FutureMark 3DMark05
FutureMark 3DMark06
Gaming Benchmarks
All gaming benchmarks are run through at a demanding stage of the game with no savepoints to affect FPS. These are manual run-though’s approximating 3 minutes and all gaming benchmarks are run three times through the same points for consistency. We hope that this gives an accurate and interesting depiction of “real-life” gaming situations. Note the resolutions and AA each game was run at.
All gaming tests were performed in Windows Vista Ultimate, under DX10 if available.
Call of Duty 4 – 1920 x 1200, 4 x AA set in-game
Oblivion – 1920 x 1200, 4 x AA set in drivers and HDR set on in-game. Settings on “Ultra”
F.E.A.R. – 1920 x 1200, 4 x AA set in game, soft shadows enabled
Bioshock – 1920 x 1200, all settings to maximum in-game
Unreal Tournament 3 – all settings set to maximum in-game
Company of Heroes – DirectX10 patch. 1920 x 1200 with in game settings as here.
Crysis – 1680 x 1050, all in-game settings set to “High”
Again, all game run-through’s are repeated three times for consistency and accuracy.
We hope that this represents a good band of games and benchmarks for people wanting a performance overview of gaming at this current time.
Cards tested
Here are the cards tested in the benchmarking:
XFX 9600 GT Alpha Dog XXX Edition 512mb
Asus 9600 GT. GPU: 650MHz. Memory: 900MHz (2000MHz). Stream processor clock: 1650MHz.
Asus 8800 GT Top Edition. GPU: 700Mhz. Memory: 1000MHz (2000MHz). Stream processor clock: 1650MHz
XFX 8800 GTS 512 XXX Alpha Dog Edition. GPU: 678Mhz. Memory: 986 (1972MHz). Stream processor clock: 1650MHz.
Powercolor HD3850. GPU: 720Mhz. Memory: 900MHz (1800MHz). Stream processor clock: 690Mhz.
MSI 8800GTX. GPU: 575Mhz. Memory: 900 (1800). Stream processor clock: 1350MHz.
Overclocking of all of the Nvidia cards tested was performed in the Nvidia drivers using the Ntune add-on.
