Zotac RTX 2070 AMP Extreme Review
Clock Speeds
The OC Scanner is nVidia’s own automatic overclocking utility which tests the card rigorously and allows you fine granular control over the voltages across the curve. As you can see from our average boost clock graph the Zotac AMP Extreme is an absolute monster. It’s nearly the fastest card in the graph out of the box, let alone overclocked.
