ADATA XPG Lancer Blade 6000MT/s DDR5
White Non-RGB Up Close
The heatsink design and underlying performance apply just as much to the white kit as they did to the black. In fact the only real difference is our kit is the RGB-free low profile option. As we said in our introduction, a model to suit all requirements.
Of course you can have an RGB white model if you like, but that’s not our focus right now. It is, after all, just the white version of the black one we saw on the previous page. Lovely, but we’ve covered the majority of it.
If you’ve spent all your money on a DDR5 kit then you might go with an Air cooler for budgetary reasons, and that’s where the low-profile kit comes in. None of the gaudy RGB. None of the height issues. Flat, super fast RAM. We love that XPG are ticking off so many options without diminishing the underlying performance.
See. Even without the RGB the design of the XPG kits catch the eye as so much of the rest of our rig is lit up.
Even the silver logo matches the rest of our system perfectly. Simple but effective.
With a model to suit all size and speed requirements, as well as white and black, RGB and non-RGB, the XPG Lancer Blade range ticks every box.
Discuss the ADATA XPG Lancer Blade 6000MT/s in our OC3D Forums.
