Gears 5 Alpha Test Performance Review
The Coalition’s Gears of War 4 was one of the first games to make great use of Microsoft’s DirectX 12 API, having to utilise both the Unreal Engine 4 and DirectX 12 to deliver great PC visuals for the time. Sadly, the game was let down by its exclusivity to the Windows/Microsoft Store and the early issues surrounding UWP, but it ultimately set up Microsoft for a major shift towards PC gaming.
Today, Microsoft’s Xbox brand has extended itself beyond console hardware, having released all of their first-party exclusives on both PC and Xbox One in recent years while also revealing plans to bring their future PC titles to gamers outside of the Microsoft Store, opening themselves to both Steam and other storefronts. Xbox Game Pass for PC has also showcased clear ambitions for the PC platform, heralding a closely connected future for their next-generation Xbox and Windows PC.
With Gears 5, which has dropped the “of War” section of its title, The Coalition plans to deliver gamers on Xbox and PC better visuals than before, the longest campaign in the series’ history and top-tier support for both PC and Xbox One. Gears 5 will also be the first series entry to release on Steam, marking a major shift for the series.
Over the past few days, we have been having a look at Gears 5’s Alpha test, which has allowed us to test the current PC version of the game to generate some performance data, setting clear expectations for the final game while also giving us some comparison data for future use. When the game releases in September we will see how well the game performs on PC, and how much optimisation has taken place since this week’s Alpha test.
CPU Performance and Scaling
CPU-wise, Gear 5 is a game that clearly benefits from high core counts, a factor that makes sense given the game’s use of DirectX 12 and its status as an Xbox exclusive. The Coalition needs to get every ounce of CPU/GPU performance out of Microsoft’s Xbox One and Xbox One X as possible. With this in mind, it makes sense that the developer will try to make use out of every core that the console, and by extension Windows PC, offers.
One thing to note before looking at the graph below is that lower core count processors experience longer load time in Gear 5’s Alpha, which makes sense as less CPU grunt is available to load levels and assets.
As you can see below, Gears 5’s Alpha plays well at Ultra on systems with more than four capable CPU cores but prefers systems with higher core/thread counts. Our dual-core system stuttered frequently during both gameplay and within the game’s benchmarking tool. We would recommend running Gears 5 on a PC with more than four strong cores. Thankfully all modern gaming-grade CPUs offers at least 4 strong cores/threads.
GPU drivers
When testing Gears 5’s Alpha, we opted to use the newest drivers from both the Radeon and Geforce camps, utilising AMD’s Radeon Software Adrenalin Edition 19.7.2 driver as well as Nvidia’s Geforce 431.36 driver.
Testing Methodology
OC3D is a website that is dedicated to PC hardware, so you better believe that we test every game on a wide range of hardware configurations. This commitment to variety means that we will be using both Intel and AMD based testbeds as well as a range of GPU offerings from both Nvidia and Radeon.
Our primary test system uses Intel’s X99 platform, containing an Intel Core i7 6850K at a fixed clock speed of 4GHz. This testbed will use 32GB of Corsair Vengeance DDR4 memory and will be powered and cooled by an HX1200i PSU and an H110i AIO liquid cooler respectively, with everything sitting inside a Corsair 460X chassis. In this system, we are using an ASUS Strix X99 motherboard.
The system below will be used to conduct the majority of our game testing. This system will be used in this review unless otherwise stated.
Game Test Rig
Intel i7 6850K @4.0 GHz
ASUS X99 Strix
Corsair Vengeance LP 4x8GB DDR4 3200MHz
Corsair HX1200i
Corsair H110i GT
Windows 10 x64 “May 2019 Update”
