OCZ Vertex TURBO 120GB Solid State Drive
While the Gskill drive appeared to be better at random file creation, the OCZ Vertex Turbo was the quicker drive over the much longer test of 100GB. The GSkill just took the spoils in the Unreal Tournament III level loading test while the OCZ won overall with the Vista boot time/shutdown. This goes to show that you cannot place too much faith in synthetic benchmarks because if I were to go off these ‘realworld test’ then the OCZ Vertex Turbo would clearly be the higher performing drive.
