Super Talent 128GB SATA II SSD
CrystalDiskMark
CrystalDiskMark is an excellent free utlity for evaluating the performance of any hard drive in your system, the test comprises of two tests, sequential read/write and a random read/write test. The results below were obtained through running 5 rounds of the 500MB test.
Results Analysis
As you can see from the results above the Super Talent FTM28GX25H puts in an excellent performance, beating the OCZ Vertex and in some cases even the OCZ Summit in most tests. In the 4k Read test the ST FTM28GX25H beats off both of OCZ’s offerings and then holds its own in the Write test equaling the OCZ Summit.
With the 512k Read test the OCZ Summit pulls ahead but is then reigned back in again by the FTM28GX25H in the 512k Write test.
Moving onto the Sequential Read test the OCZ drives have the edge but once again the FTM28GX25H narrows this on the Sequential Write test. One thing to remember guys is that as newer firmware is released we should expect to see increased performance from the FTM28GV25H.
Lets move on and take a look at some ATTO benchmarks.
