Aria.co.uk Gladiator 1155 i5 4.4GHz Bundle
Alien vs Predator
Finally we look at our usual couple of games. AvP is similar to 3D Mark in that, barring some aberration, you should see the same scores from the same GPU. As we do here.
Crysis Warhead
Crysis has always been a little more varied in its results and so it proves. Still very close to 60 FPS though, so the GTX570 used definitely has enough grunt behind it to keep it pumping the eye-candy out.
