Cyberpower Hyper Liquid Ultra 7 GTX Ti Review
All Lit Up
The small slivers of RGB lighting on the IO and chipset heatsink sections of the MSI X470 Carbon are absolutely dominated by the combination of LED strip and LED fans at the heart of the Hyper Liquid Ultra 7 GTX Ti. Even the RGB lighting on the DDR4 grabs your attention more easily. You can also see from the wall how bright the lighting is with two 200mm fans in the front and the brightness and placement of the RGB strip within the case mean that the whole area around your system will be represented by your colour choice.
