Amazon lists AMD’s Ryzen 5 3600XT and Ryzen 9 3900XT processors
Amazon lists AMD's Ryzen 5 3600XT and Ryzen 9 3900XT processors
The European arm of Amazon has listed AMD’s rumoured Ryzen 5 3600XT and Ryzen 9 3900XT processors, listing a release date of July 7th for both processors. This launch will be the second time that AMD has released Ryzen 3000 series processors on the 7/7 date.
According to Videocardz, the Ryzen 5 3600XT was listed with a UK price fo €284 and AMD’s Ryzen 9 3900XT was listed for €570. Both prices are much higher than the prices of their non-XT counterparts.
Rumour has it that AMD plans to reveal its Ryzen 3000XT series processors on June 16th, offering PC builder higher clock speeds than AMD’s existing Ryzen 3000X series processors in both single-threaded and multi-threaded applications.
Below are the rumoured specifications of AMD’s Ryzen 3000XT processors, including a model called the Ryzen 7 3800XT, which wasn’t listed by Amazon.
  Cores Threads Base Clock Boost Clock L2 + L3 Cache PCIe 4.0 Lanes TDP Pricing
Ryzen 9 3950X 16 32 3.5GHz 4.7GHz 8+64 MB 16+4+4 105W $749
Ryzen 9 3900XT
(Leaked)
12 24 4.1GHz 4.7GHz 6+64 MB 16+4+4 ? ?
Ryzen 9 3900X 12 24 3.8GHz 4.6GHz 6+64 MB 16+4+4 105W $499
Ryzen 9 3800XT
(Leaked)
8 16 4.2GHz 4.7GHz 4+32 MB 16+4+4 ? ?
Ryzen 7 3800X 8 16 3.9GHz 4.5GHz 4+32 MB 16+4+4 105W $399
Ryzen 7 3700X 8 16 3.6GHz 4.4GHz 4+32 MB 16+4+4 65W $329
Ryzen 5 3600XT
(Leaked)
6 12 4.0GHz 4.7GHz 3+32 MB 16+4+4 ? ?
Ryzen 5 3600X 6 12 3.8GHz 4.4GHz 3+32 MB 16+4+4 95W $249
Ryzen 5 3600 6 12 3.6GHz 4.2GHz 3+32 MB 16+4+4 65W $199
Ryzen 3 3300X 4 8 3.8GHz 4.3GHz 2+16MB 16+4+4 65W $120
Ryzen 3 3100X 4 8 3.6GHz 3.9GHz 2+16MB 16+4+4 65W $99
You can join the discussion on Amazon listing AMD’s Ryzen 5 3600XT and Ryzen 9 3900XT processors on the OC3D Forums.
