AMD Ryzen 3900XT, 3800XT and 3600XT Specs Leak
AMD Ryzen 3990XT, 3800XT and 3600XT Specs Leak
Rumour has it that AMD plans to release so-called “Matisse Refresh” CPUs, enhanced versions of AMD’s existing Zen 2 powered Ryzen 3000 series processors with increased clock speeds and other improvements. Some have also claimed that these processors can handle faster memory speeds while maintaining fast 1:1 Infinity Fabric Ratios.
So far, AMD has been silent on the issue, but Videocardz has now reported on leaked clock speeds for AMD’s new Ryzen 3000XT lineup: leaks which come via Chiphell. These processors are reportedly due to be announced in mid-June, which is when AMD’s B550 motherboard socket is due to launch.
So far, three Ryzen 3000XT series processors have come to light, AMD’s Ryzen 9 3900XT, Ryzen 7 3800XT and Ryzen 7 3600XT. All of these processors will feature base and boost clock speed enhancements of 200-300MHz, delivering end-users significant performance bumps in single-threaded and multi-threaded workloads. In the case of the Ryzen 9 3900XT, boost clock speeds will reach as high as 4.8GHz.
If these rumoured Ryzen SKUs are legitimate, these clock speed boosts will act as a counter to Intel’s recently released Comet Lake series of processors. It is also possible that these new SKUs will release with the same pricing as each XT model’s existing X series variant, effectively price-cutting AMD’s existing Ryzen 3000 series processors. If true, this release would grant AMD more performance in the high-end while also delivering more value within the mainstream market.
  Cores Threads Base Clock Boost Clock L2 + L3 Cache PCIe 4.0 TDP Price
Ryzen 9 3950X 16 32 3.5GHz 4.7GHz 8+64 MB 16+4+4 105W $749
Ryzen 9 3900XT 12 24 4.1GHz 4.8GHz 6+64 MB 16+4+4 ? ?
Ryzen 9 3900X 12 24 3.8GHz 4.6GHz 6+64 MB 16+4+4 105W $499
Ryzen 9 3800XT 8 16 4.2GHz 4.7GHz 4+32 MB 16+4+4 ? ?
Ryzen 7 3800X 8 16 3.9GHz 4.5GHz 4+32 MB 16+4+4 105W $399
Ryzen 7 3700X 8 16 3.6GHz 4.4GHz 4+32 MB 16+4+4 65W $329
Ryzen 5 3600XT 6 12 4.0GHz 4.7GHz 3+32 MB 16+4+4 ? ?
Ryzen 5 3600X 6 12 3.8GHz 4.4GHz 3+32 MB 16+4+4 95W $249
Ryzen 5 3600 6 12 3.6GHz 4.2GHz 3+32 MB 16+4+4 65W $199
Ryzen 3 3300X 4 8 3.8GHz 4.3GHz 2+16MB 16+4+4 65W $120
Ryzen 3 3100X 4 8 3.6GHz 3.9GHz 2+16MB 16+4+4 65W $99
You can join the discussion on AMD’s rumoured Ryzen 3900XT, 3800XT and 3600XT processors on the OC3D Forums.
